Not works at BIN 1 my APX60 mono camera
Hi Friends! (SORRy if I duplicated this message)
My apx60 mono (Atik) camera not Works correctly when I use Frame and Focus, Flats aid, plate solve or focus control in BIN1.
What is solution?
Link to Logs
Useful Info
OS: Microsoft Windows 10 Pro
Ver: 4.2.0.968 (64-bit)
.NET: 4.8
ASCOM: 6.5.0.3091
I have reviewed the logs you sent, but there are no errors present in the logs. These logs cover 4 frame and focus frames and all performed as expected. You are certain these logs cover an instance of the error you describe? Please note that every time you start SGPro a new log is created. Because of this, you may need to use the issue reporting tool to send logs from previous sessions.
I send an other message with other log. If not works this log I think to send a video capture to see my problem. Thanks
