Odd behaviour Meridian flip and dome slaving
Set-up:
  • SGP
  • Mesu 200 mount via “SiTech-II telescope” in equipment profile
  • UNIWERSAL dome via “LesveDomeNet” in equipment profile
Last night I was imaging M42.
As time for an Automatic Meridian Flip was nearing, I got a dialog box saying that the next frame was too long and that there were 17 seconds remaining before the meridian.
I overrode the count-down (–possibly should not have–) and told SGP to flip in the dialogue box. (I can’t find the dialogue box in the documentation, so I don’t recall the precise wording.)
The mount did not move (!), but the dome slewed.
The Auto MF process started to platesolve: the platesolve failed, probably because the dome had moved, but not the scope. The camera had taken a picture of the dome wall.
Equipment profile is set to Auto MF.
  • Auto MF is set to “Wait for Meridian” and “Auto-center after MF”.
  • Minutes past horizon: 0.
  • Auto MF auto-close delay: 30
Could anyone tell me what I may have done wrong for the scope not to move upon Auto MF?
Thank you,
Kris
On many scopes, SGP does a flip by sending a slew command to the scope. In that case, if the scope thinks it is before the meridian, no flip will happen. It’s best to wait until a few minutes after the meridian before attempting a flip because the meridian time in SGP and the scope may not precisely agree.
Thank you, DesertSky,
for your useful input.
I’ll adjust my settings to flip a few minutes post-meridian.
I’ll play around with this when I return to my observatory in March…
Are you using the same set-up by any chance?
Any suggestions on whether it is preferable in SGP to use POTH twice (for scope and dome) rather than a direct connection to SiTech II and LesveDomeNet?
Best regards,
Kris
Kris:
I don’t have any experience with domes but based on other responses I have seen I think you want to have SGP control the scope and the dome directly without POTH.
