Hello, does anyone know if the Ascom driver is compatible 64 bits. I’m trying to figure out which drivers may work if I migrate.
Thank you
Alnitak uses a direct serial connection so it is compatible with 64bit. Unless you’re referring to the CoverCalibrator ASCOM driver, in which case I’m not sure.
