I was having problems with star smearing in some of my frames. Eventually tracked it down to using backlash compensation and temperature compensation at the same time. Watching closely the bottom of screen messages and the focuser panel, it looks like SGP finishes a frame, downloads, then runs temperature compensation, then starts a new frame. Problem is, there seems to be no check to make sure temperature compensation is finished before starting a new frame. This isn’t a problem if you’re not using backlash compensation as it clicks the number of focuser steps quickly enough before the next frame starts. But if you’re using backlash compensation the focuser is running out the specified number of steps then in again after the frame has started (in my case for about the first 4 sec of a 30s sub). There is enough torque from the focus motor or image shift during the backlash compensation to ruin the frame with smeared stars.
Particularly when using backlash compensation there needs to be a pause so that focuser movement can finish before the next frame starts. Any thoughts on this?
…Keith
