Hi
I am using the latest ver 2 and have set up to auto focus when the temp changes by 2 deg , but PHD does not
pause while auto focusing ( with the obvious problems ) I do have the option selected !!!
Any body else seen this ?
Harry
Hi
Harry
Hi Harry,
Have you got ‘settle auto guider before auto focus frames’ ticked in guiding settings? I think this will cause the behaviour you’re seeing.
Cheers,
Ian
Hi
Yes I had got that ticked , thought that was only for the start of auto focus !!! --wrong as usual
I will do as you suggest , many thanks
Reagrds
Harry
I too thought it meant the start of the the autofocus run, but no, it means it will settle before every autofocus frame.
Cheers,
Ian
Hi
Tried this last night and all works fine
But PHD does not seem to pause , it carrys on issuing corrections , its just SGP does not wait for anything from PHD !
not sure if this is the correct behaviour or not !!!
Harry
