I am a new used to SGP and have been particularly impressed with its plate solving abilities, particularly the facility to fetch the coordinates of an image on Astrobin and then precisely align a single frame or mosaic against that image. I have however experienced considerable frustration with the SGP to PHD2 setup and have done some initial problem determination to isolate the cause.
What I can say for certain is that PHD2 works very well for me when it is not under the command of SGP. If I do not have SGP running at all then I know that I can get consistent good guiding results with PHD2. As I see it I have two choices.
Invest time and effort trying to establish the root cause of the SGP/PHD2 issue via log analysis, tinkering with settings and waggling cables.
Allow SGP to plate solve and run its sequences but do not allow it to control guiding which I will initiate manually.
Option 2 is my preferred route as it allows me to select a star that is not saturated which PHD2 seems perversely insistent on doing when it auto-selects a star.
My question is how do I instruct SGP to proceed with its sequences whilst leaving guiding under my manual control? I have tried selecting the ‘No auto guider’ option from the guiding interface options however SGP insists on starting PHD2 nevertheless and then getting upset and hangs when it doesn’t get its way. I have not yet tried removing the install path for PHD2 in the settings. Would this help?
For the moment I would like SGP to end the bad relationship it has with PHD2 on my system and move on with its life. Perhaps they can have a reconciliation at a later time but for now I don’t want them to speak to each other. How can I achieve this please?
For reference SGP will mostly start PHD2 successfully (around 70% of the time) and will commence guiding but having lured me in to a false sense of security the guiding wanders off on both RA and DEC. I don’t doubt this problem can be solved but for now I want to circumvent it.
Apart from this I’m impressed with SGP.
Neil
