PHD2 startup difference on abort/re-run
I noticed a small difference in how SGP treats PHD2 if you abort a sequence.
I started a sequence wiithout anything connected to begin with and with a start time. Before the time was reached I decided to change the start time and aborted the sequence (did not run end of sequence) and reset the sequence, preserving progress. I disconnected PHD2 manually from the devices and shut it down. The SGP equipment was still connected.
When I ran the sequence again, I noticed it did not open PHD2. I aborted again, reset the sequence and disconnected all in SGP. When I ran the sequence this time, PHD2 fired up and connected. I’m not sure SGP can do anything about it but it is useful to know about this little gotcha.
