All I am using pinpoint to solve
In the left bottum it says that the solve is completed but no popup is showing up with the coordinates
Any Clue,
Chris
Any Clue,
Chris
Are you attempting to plate while no sequence is running (manually)? Or are you referring to the plate solve performed as part of a sequence running?
Manually with Pinpoint, I moved away from Pinpoint and used Platesolve 2 that works for now on the image
Chris
Hmm, ok. I’ll see if I can reproduce this…
Ken
This was in the logs after loading RAW CR2 Canon file in to SGP, but with hints
[09/18/19 14:36:05.891][DEBUG] [Image Plate Solve Thread] SaveFileBmp16: Locking bitmap for disk write…
[09/18/19 14:36:05.921][DEBUG] [Image Plate Solve Thread] SaveFileBmp16: Opening file stream…
[09/18/19 14:36:05.923][DEBUG] [Image Plate Solve Thread] SaveFileBmp16: Writing FITS headers…
[09/18/19 14:36:05.923][DEBUG] [Image Plate Solve Thread] SaveFileBmp16: Traversing and persisting bitmap data…
[09/18/19 14:36:06.355][DEBUG] [Image Plate Solve Thread] SaveFileBmp16: FITS block fill…
[09/18/19 14:36:06.355][DEBUG] [Image Plate Solve Thread] SaveFileBmp16: Unlocking bitmap…
[09/18/19 14:36:06.355][DEBUG] [Image Plate Solve Thread] SaveFileBmp16: Closing file stream
[09/18/19 14:36:06.387][DEBUG] [Image Plate Solve Thread] ************* SOLVE HINTS ****************
[09/18/19 14:36:06.387][DEBUG] [Image Plate Solve Thread] SOLVER: Pinpoint
[09/18/19 14:36:06.388][DEBUG] [Image Plate Solve Thread] BLIND: False
[09/18/19 14:36:06.388][DEBUG] [Image Plate Solve Thread] METHOD: Use up to magnitude 20 stars
[09/18/19 14:36:06.388][DEBUG] [Image Plate Solve Thread] RA: 20,9516666666667
[09/18/19 14:36:06.388][DEBUG] [Image Plate Solve Thread] DEC: 31,2166666666667
[09/18/19 14:36:06.388][DEBUG] [Image Plate Solve Thread] SCALE: 1,04
[09/18/19 14:36:06.388][DEBUG] [Image Plate Solve Thread] ******************************************
[09/18/19 14:36:06.791][DEBUG] [Image Plate Solve Thread] Plate Solve Hint RA: 20,9516666666667
[09/18/19 14:36:06.791][DEBUG] [Image Plate Solve Thread] Plate Solve Hint DEC: 31,2166666666667
[09/18/19 14:36:06.791][DEBUG] [Image Plate Solve Thread] Plate Solve Hint Scale: 1,04
[09/18/19 14:36:06.791][DEBUG] [Image Plate Solve Thread] Plate Solve Hint Angle: 0
[09/18/19 14:36:06.791][DEBUG] [Image Plate Solve Thread] Plate Solve Search: Use up to magnitude 20 stars
[09/18/19 14:36:06.791][DEBUG] [Image Plate Solve Thread] Plate solve binning:
[09/18/19 14:36:06.791][DEBUG] [Image Plate Solve Thread] Plate solve exp len: 0
[09/18/19 14:36:11.586][DEBUG] [Image Plate Solve Thread] *********** SUCCESSFUL SOLVE *************
[09/18/19 14:36:11.586][DEBUG] [Image Plate Solve Thread] SOLVER: False
[09/18/19 14:36:11.586][DEBUG] [Image Plate Solve Thread] SUCCESS: False
[09/18/19 14:36:11.586][DEBUG] [Image Plate Solve Thread] CONF: 0
[09/18/19 14:36:11.587][DEBUG] [Image Plate Solve Thread] BLIND: False
[09/18/19 14:36:11.587][DEBUG] [Image Plate Solve Thread] RA: 0
[09/18/19 14:36:11.587][DEBUG] [Image Plate Solve Thread] DEC: 0
[09/18/19 14:36:11.587][DEBUG] [Image Plate Solve Thread] SCALE: 0
[09/18/19 14:36:11.587][DEBUG] [Image Plate Solve Thread] FLIPPED: False
[09/18/19 14:36:11.587][DEBUG] [Image Plate Solve Thread] ANGLE (EON): -500
[09/18/19 14:36:11.587][DEBUG] [Image Plate Solve Thread] MSG: Solve failed! The plate’s exposure start time is required for catalog proper motion calculation. Check the attached image.
[09/18/19 14:36:11.587][DEBUG] [Image Plate Solve Thread] ******************************************
[09/18/19 14:36:11.587][DEBUG] [Image Plate Solve Thread] Image Plate Solve: Failed to solve image…
[09/18/19 14:36:11.587][DEBUG] [Image Plate Solve Thread] Invoking blind failover…
But with taken image from SGP saved as fit, it work direct.
When loading CR2 files, it looks like the time of capture is missing. while save saving the file is actually the capture date. What do you think about my analyse. for now. Because CR2 is not fit file and has no information at all
I am happy with Platesolve2 what is working for me.
Anyway it would be handy or Tip for RFC that in the left in the bottum, the status of sloving becoming more clear example change to “invoking blind failover” en not to completed which is the status of solve and adding timer counting the duration of the running (blind)solve in seconds seem handy to me
Chris
