Plate Solve 2.28
I’m having a problem with Plate Solve 2.28.
When I run Plate Solve in SGP using ASTAP, it works.
When I run Plate Solve 2.28, I get the following message:
Failed to plate solve image: Unanticipated problem during plate matching.
When I use the program Plate Solve 2 (not via SGP), there’s no problem.
Link to Logs
https://www.dropbox.com/scl/fi/ug1t73n8285hwda26dcq3/sgpro_log_archive_1af45ecc-f918-4423-97bf-8f82f9d31ae7.zip?rlkey=599vlwml5qb7nque4citwmf8h&dl=0
Useful Info
OS: Microsoft Windows 10 Home
Ver: 4.4.1.1441 (64-bit)
.NET: 4.8
ASCOM: 7.0.2.4675
You didn’t include a log that showed a plate solve attempt, but the issue you are likely referring to is from v2.28 where the PS2 app does not override regional settings and stores solve data in a test file with numbers separated by commas. If your region uses commas as decimal separators then SGPro does not know how to read them. I do believe PS2 v2.29 fixes this.
