The attached logs to not cover the specified timeframe, but, in addition to the gemini setting @promero noted, SGPro also has a setting that directs the plate solver to sync (or not). It is set to sync by default, but it has been changed accidentally before. In the Control Panel on the Telescope tab, check the field labeled “Sync Behavior” and make sure it is NOT set to a type that reads offset.
