Plate solve not used, will start
I do not want to use platesolving so I got it unchecked in my targets.
But when I start the sequence it DOES START to plate solve.
How do I disable it totaly?
Is it correct that I CANNOT USE MY ROTATOR without platesolving? ???
I think it is because you have the “Rotate camera to” set. SGP has two ideas of camera rotation: the physical angle reported by the rotator and the angle relative to the sky (degrees clockwise of north). When you use this feature, SGP is taking it as a sky angle. There is not a fixed relationship between physical angle and sky angle - it depends where your telescope is pointing. So to determine sky angle a plate solve is needed. If you want the physical angle of the rotator, turn this option off and set the rotator manually before starting.
Crap. Not so very nice, I’ve got 2 targets in 1 night, with different rotations of the camera.
I just want the rotator to set to 45 degrees, not to some relative sky angle etc.
Just turn the rotator to absolute x degrees.
This is no use to me :frowning:
