I changed some settings in SGP. A new sequence starts and I get the error “The sequence requires the use of a plate solve, but none is selected! Please select one in the control panel plate solve tab and try again.
I tried the tab for “No plate solve” No luck.
I don’t have a plate solve installed and I use the celestron CPWI for alignment. I just am not that advanced yet. I never the less chose one that connected. I again tried to do the sequence and received a message “ the sequence requires the use of a plate solve, but your image scale is set to zero! Please provide a valid scale in the control panel tab and try again. I tried this and I ended back at step 1…
How do I go back to where the sequence worked. Not using plate solve?
Bill H.
