Hi! So here’s the thing. Platesolving was working just fine, but I misunderstood something regarding the offline plate solving. So eventually I re-installed everything and change the port number from the default 8080 to 8081 since i wrongly understood that the port had something to do with my offline solving cappabilities… The thing is, when I tried plate solving again it didin’t work. It did capture the plate solve image but when it starting solving it it failed everytime. It did have enought stars in the region, and just in case you wonder, the object is M83.
So I went into the config file for the blind solve failover and it didn’t load (http://127.0.0.1:8080/api/config) . The address on the URL that pops up was not 8081, but 8080. Tried changing the URL to see if that would load the config page, and it did. But still didn’t solve. Tried re-installing it again and going back to 8080 port but still doesnt work. How do I go about it?
Thanks in advance! I’m really stuck
The camera is an ASI1600 MM and the software is SGPRO 2.6
Here are my logs from last night. I’m attaching the whole log and here’s the part where i tried solving
[02-11-18 21:46:32.645][DEBUG] [Camera Thread] SGM_CAMERA_PLATE_SOLVER_CAPTURE complete…
[02-11-18 21:46:32.746][DEBUG] [Telescope Thread] Auto center verification frame complete. Plate solving image C:\Users\Guillo\AppData\Local\SequenceGenerator\Temp\plate_solve_image.fit
[02-11-18 21:46:32.852][DEBUG] [Telescope Thread] ************* SOLVE HINTS ****************
[02-11-18 21:46:32.852][DEBUG] [Telescope Thread] SOLVER: PlateSolve2
[02-11-18 21:46:32.852][DEBUG] [Telescope Thread] BLIND: False
[02-11-18 21:46:32.852][DEBUG] [Telescope Thread] METHOD: 100 Regions
[02-11-18 21:46:32.852][DEBUG] [Telescope Thread] RA: 5.68534008434385
[02-11-18 21:46:32.852][DEBUG] [Telescope Thread] DEC: -2.19457816694192
[02-11-18 21:46:32.854][DEBUG] [Telescope Thread] SCALE: 2.07993
[02-11-18 21:46:32.854][DEBUG] [Telescope Thread] ******************************************
[02-11-18 21:46:34.270][DEBUG] [Telescope Thread] FitsFileHeaderData: Angle - 0
[02-11-18 21:46:34.270][DEBUG] [Telescope Thread] FitsFileHeaderData: Scale - 0
[02-11-18 21:46:34.285][DEBUG] [Telescope Thread] FitsFileHeaderData: RA - 5.68534151695866
[02-11-18 21:46:34.301][DEBUG] [Telescope Thread] FitsFileHeaderData: DEC - -2.19459958734691
[02-11-18 21:46:34.312][DEBUG] [Telescope Thread] PlateSove2 Param: RA (RAD) - 1.48841855351118
[02-11-18 21:46:34.312][DEBUG] [Telescope Thread] PlateSove2 Param: DEC (RAD) - -0.0383026147055183
[02-11-18 21:46:34.312][DEBUG] [Telescope Thread] PlateSove2 Param: Width - 2328
[02-11-18 21:46:34.312][DEBUG] [Telescope Thread] PlateSove2 Param: Height - 1760
[02-11-18 21:46:34.312][DEBUG] [Telescope Thread] PlateSolve2 Command Line:
[02-11-18 21:46:34.312][DEBUG] [Telescope Thread] C:\Users\Guillo\AppData\Local\SequenceGenerator\PlateSolve2.exe 1.48841855351118,-0.03830261470552,0.02347505193978,0.01774746194760,100,C:\Users\Guillo\AppData\Local\SequenceGenerator\Temp\psXSolve_0.fit
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] *********** SUCCESSFUL SOLVE *************
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] SOLVER: False
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] SUCCESS: False
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] CONF: 0
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] BLIND: False
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] RA: 0
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] DEC: 0
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] SCALE: 0
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] FLIPPED: False
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] ANGLE (EON): -500
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] MSG: PlateSolve 2 failed! No APM file found.
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] ******************************************
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] Auto center validation frame failed to solve. PlateSolve 2 failed! No APM file found.
[02-11-18 21:46:49.879][DEBUG] [Telescope Thread] Auto center validation frame solve failed, invoking blind failover…
[02-11-18 21:46:49.880][DEBUG] [Telescope Thread] Astrometry.NET: Sequence endpoint data: Astrometry.NET (Remote)
[02-11-18 21:46:49.881][DEBUG] [Telescope Thread] Astrometry.NET: Sequence endpoint data: Astrometry.NET (Remote)
[02-11-18 21:46:49.907][DEBUG] [Telescope Thread] ************* SOLVE HINTS ****************
[02-11-18 21:46:49.907][DEBUG] [Telescope Thread] SOLVER: Astrometry.NET
[02-11-18 21:46:49.907][DEBUG] [Telescope Thread] BLIND: True
[02-11-18 21:46:49.907][DEBUG] [Telescope Thread] METHOD: 100 Regions
[02-11-18 21:46:49.907][DEBUG] [Telescope Thread] RA: 5.68534008434385
[02-11-18 21:46:49.907][DEBUG] [Telescope Thread] DEC: -2.19457816694192
[02-11-18 21:46:49.907][DEBUG] [Telescope Thread] SCALE: 2.07993
[02-11-18 21:46:49.907][DEBUG] [Telescope Thread] ******************************************
[02-11-18 21:46:49.907][DEBUG] [Telescope Thread] Astrometry.NET: Sequence endpoint data: ANSVR (Local Astrometry.NET)
[02-11-18 21:46:50.056][DEBUG] [Telescope Thread] Astrometry.NET convertedAstrometry.fits path: C:\Users\Guillo\AppData\Local\SequenceGenerator\Temp\convertedAstometry.fits
[02-11-18 21:46:50.056][DEBUG] [Telescope Thread] Astrometry.NET - File is too large, resizing
[02-11-18 21:46:50.086][DEBUG] [Telescope Thread] Astrometry.NET - Saving file
[02-11-18 21:46:50.086][DEBUG] [Telescope Thread] SaveFileBmp16: Locking bitmap for disk write…
[02-11-18 21:46:50.086][DEBUG] [Telescope Thread] SaveFileBmp16: Opening file stream…
[02-11-18 21:46:50.086][DEBUG] [Telescope Thread] SaveFileBmp16: Writing FITS headers…
[02-11-18 21:46:50.087][DEBUG] [Telescope Thread] SaveFileBmp16: Traversing and persisting bitmap data…
[02-11-18 21:46:50.181][DEBUG] [Telescope Thread] SaveFileBmp16: FITS block fill…
[02-11-18 21:46:50.181][DEBUG] [Telescope Thread] SaveFileBmp16: Unlocking bitmap…
[02-11-18 21:46:50.181][DEBUG] [Telescope Thread] SaveFileBmp16: Closing file stream
[02-11-18 21:46:50.185][DEBUG] [Telescope Thread] Astrometry.NET using endpoint: http://127.0.0.1:8080/api/
[02-11-18 21:46:50.185][DEBUG] [Telescope Thread] Astrometry.NET - Calling Async Solve
[02-11-18 21:46:51.240][DEBUG] [Unknown] Exception in Astrometry.NET Solver: No es posible conectar con el servidor remoto
[02-11-18 21:46:51.241][DEBUG] [Unknown] Astrometry.NET solve done in 0 seconds.
[02-11-18 21:46:52.187][DEBUG] [Telescope Thread] Astrometry.NET - Solve Completed
[02-11-18 21:46:52.187][DEBUG] [Telescope Thread] Astrometry.NET - Failed to solve image.
sg_logfile_20180211214415.txt (141.4 KB)
