Plate solver nag
Sequence require a plate solving but none are selected, I cant run any sequence please help! I DONT WANT A FREAKING PLATE SOLVING AND I DISABLED IT IN CONTROL PANEL. I CANT EVEN USE THIS SOFTWARE I PAYED FOR.
It sounds like you are using a Wizard that selects your target via Plate Solving. If you don’t want Plate Solving in any way you can’t run the Mosaic and Framing Wizard or click on Centre Here, Plate Solve, or Blind Solve. That leaves you with only manually directing your mount to the targets and this great software will do everything else for you. It seems a bit of a waste having such good software that relies on Plate Solve and then disabling it though.
I was testing a setup since its cloudy for the week and not using any wizard. I only created a hardware profile and add the camera and filter then disable plate solving to test it. You cant run a test sequence even if the plate solving is disabled. It is crazy to get an error and tell tou to disable plate solving which is already disabled, it does not make sense.
I am sure I have run a sequence without plate solve. Can you have a look at target settings (click on the gear wheel next to the target name) and see if you have the Center option ticked. This tells SGP to use Plate Solve to center the telescope when the sequence starts and can be ticked even if you haven’t set up Plate Solve. The error message is simply telling you that you have set up contradictory settings like this one.
The error should be telling you which settings you need to change. We have no way of knowing if you accidentally disabled the plate solver or if you selected those options not knowing a plate solver was required.
