If I interrupt the plate solve before it has a plate match then the Green Status Bar for Plate Solve (in Control Panel) just keeps cycling, even though no plate solve is occurring. It doesn’t affect anything, but it is annoying. It has been like this even in ver 2.0. Is it an issue you are aware of?
Is it perhaps trying to resolve a blind solve?
I don’t think so. What I had done was to hit the “Center Now” under Target Settings, then when the plate solve came up it couldn’t find a match so it started going into its spiral search. At that point I canceled the operation but the green bar just keeps going across as if the plate solve is still occurring…but it isn’t. Everything still works properly and I can do whatever I want but the green status bar just keeps on going.
I just came in to the forum to ask for this. I tried to plate solve a picture, it was non-sense so it warned me about something fancy. Nevertheless the message is looping from there on.
Annoying, but does not affect the sequence!
CS
Lex
So, this issue is still present. I went to plate solve an area and it failed because I had the wrong image scale in. But the green indicator just keeps running. Even after I changed the image scale and successfully plate solved that damn green indicator just keeps on going and I can’t get rid of it.
Please tell me there is a way without shutting the program down.
For the most part you can probably ignore it. Plate solving is a fairly complex process and cancelling it is somewhat annoying because of the moving pieces and the reliance of 3rd party applications. I’ll try and make it better (it annoys me as well) but for the most part it should be harmless.
