I’m currently trialling a Losmandy G8 mount which is new to me. I modified an old sequence with the new telescope to go to Andromeda(M31).
I clicked on the target name then chose ‘Slew To’. It went very close, I could actually see m31 in the frame, and I then chose center. I think it got close on it’s first attempt, (but I might be wrong I guess). On the second or third attempt it solved and then the mount slewed to totally the the wrong place.
I had the G8 hand controller in my hand and was about to hit the Stop button, when it actually hit the software limit and stopped itself.
I was shocked by what had happened, so I first parked the mount, then slewed to M31 again and the same issue occurred, wildly slewing.
I wondered whether the sequence might be corrupt, or there might be some issue in swapping telescopes in the old sequence so I created a new sequence and deleted the old one. The new one worked fine.
In my year or so of using SGPro I’d never had this before, it’s very worrying. I’m thinking one of two possibillities…
PlateSolve2 worked out a wrong place to go to, and issued it to the mount. OR
PlateSolve2 worked out the right place, but the mount mis-interpreted it.
Is there some sort of place in the software I can set a trap to stop such wild swinging?
I don’t seem to have any log files for the period, which I don’t understand
I have one sg_logfile_20200909234215.log which finished on the 10th, and then another…sg_logfile_20200913235114.log which started on the right night, but later than the incidents.
I accidently started SGPro later on in the evening, when it was already imaging, could that maybe have overwritten an earlier one.
