Hi there,
I have been having a problem getting platesolve to work when my image scale gets big with a wide field lens. If the lens is 100mm or longer, platesolve works. At 100mm my image scale is 7.5.
With my 85mm lens the image scale is 9.33 and usually, I can get 1 solve to work after starting up. But after that, I get the error every time. Yes the image scale is set in camera properties.
Log and some images attached. Thanks in advance.
Bruce
sg_logfile_20180905233711.txt (228.3 KB)
