Ken:
I am located in Austin and all the images being tested were either frame and focus images or images taken as part of a “centering” task. The failure of PlateSolve2 was solely related to those types of frames.
If I load an image previously captured by SGP as part of a sequence and saved to disk, PlateSolve2 solves those frames reliably when I reload them and do a solve. According to the PlateSolve2 Help file, it reads info from the FITS header and uses that if it can. This seems to imply the FITS headers being built as part of a target sequence and saved to disk are formatted differently or contain different info than the FITS headers being created for Frame/Focus images or Centering images.
If SGP is calculating the plate size as the displayed size of 34’ x 34’, then there is problem since my system has a pixel scale of 0.451" / arcsecond per pixel and the chip is 3326 x 2504 (KAF-8300). When PlateSolve2 successfully solves an image from a target sequence, PlateSolve2 shows the expected 25’ x 19’ plate size as well as the 0.451 plate scale:
In the FITS header of an image taken as part of a sequence and saved to disk, it appears that PlateSlove2 can retrieve the image size (3326 x 2504) and the pixel scale (0.451) and then calculate the correct image size – ignoring the 34’ x 34’ setting SGP is generating. However, when it is a Frame and Focus image, PlateSolve2 is apparently being forced to use the 34 x 34 value supplied and that is what is causing the failure.
All these images are being taken by a QSI683wsg camera so there is nothing unusual about the way they are formatted, stored, etc.
I will be back at my observatory Saturday night and I will rerun the tests and capture the SGP log file. Since these are Frame and Focus images, you want me to right click and do a “Save As Mono FITS…” and send those files along with the SGP log?
As an aside, I was using Astrometry.net as the blind failover and Astrometry.net was solving these frame and focus images in 40 seconds or less.
I did capture a snippet from the SGP log file right after one of the fails:
[8/13/2015 10:54:58 PM] [DEBUG] [Main Thread] Tried to display solved stars, but list is null
[8/13/2015 10:55:18 PM] [DEBUG] [Main Thread] PopulateDataModel: Transferring view to the data model…
[8/13/2015 10:55:18 PM] [DEBUG] [Main Thread] Performing serialize…
[8/13/2015 10:55:27 PM] [DEBUG] [Main Thread] Tried to display solved stars, but list is null
[8/13/2015 10:56:50 PM] [DEBUG] [Image Plate Solve Thread] SafeParseDouble: Input string was not in a correct format.
[8/13/2015 10:56:50 PM] [DEBUG] [Image Plate Solve Thread] FitsFileHeaderData: Angle - 124.349756022391
[8/13/2015 10:56:50 PM] [DEBUG] [Image Plate Solve Thread] FitsFileHeaderData: Scale - 0.451656374008052
[8/13/2015 10:56:50 PM] [DEBUG] [Image Plate Solve Thread] FitsFileHeaderData: RA - 20.7631240788335
[8/13/2015 10:56:50 PM] [DEBUG] [Image Plate Solve Thread] FitsFileHeaderData: DEC - 30.7434163666526
[8/13/2015 10:59:03 PM] [DEBUG] [Image Plate Solve Thread] Image Plate Solve: Failed to solve image…
[8/13/2015 10:59:03 PM] [DEBUG] [Image Plate Solve Thread] Solve failed, no blind failover option, quitting…
cm
