Platesolve2 - was GREAT now? what happened?
I installed this and first time out - it was solving my plates in under 20 seconds. (for centering) I was SO amazed.
well it’s been a couple months now and I have no idea what’s changed… but it takes 4-5 minutes! If I click stop/done it just seems to sit there and keeps SGP hung up and I often need a reboot.
Lately - it shoots the centering location. (I know its right on!) I can see the nebula and yet it can’t solve. It takes 4-5 minutes, often says failed. It sometimes complains about a hint? I just started shooting without centering because I knew I was on it.
ANY IDEAS why this would stop working so well? I’m using lum filter for plate solves and decent exposure. I click “SHOW PHOTO” and I see stars and lots of red circles on them… so it’s getting the plate quality it needs. Baffling.
This kind of thing is sometimes due to the mount reporting erroneous position data.
Do a careful star alignment and try again.
I gave up on Plare Solver 2 and went to Pin Point. It is worth it.
Rob
I think your right. I forced a plate solve (blind) and had it KEEP THE DATA - appended on park and last night I plate solved in less than 8 seconds.
I don’t do a star align and I’m in a dome. But using a tripod so things can vary slightly. I do a 30 second polemaster check and go.
Last night everything was perfect. (I now need dome rotation kit) as I can run from in the house. I also went to a hard wire by passing the hand controller and replaced the blue tooth version with a hardware and everything was supper stable last night.
what is better about pin point? Should I have problems again? Is it a pay for? does it use the same databases? When my scope has printer HINT for plate solving it smokes!
Sorry I cannot answer your question about pinpoint as I have never used it.
Plate Solve 2 works for me usually within seconds if it gets good ‘hints’ from the mount position. If it does not there is usually something wrong.
Even then a blind solve and sync usually helps to get things back in order.
Glad you got it working again.
Hey Ron,
This has happened to me on more than one occasion. Sometimes when I stop and auto centering or plate solve it looks like it stopped because the windows close down but at the bottom where the progression area is shows that it is still running. My work around to avoid a reboot has been to open the control panel and click on the plate solve tab. I then click on blind solve and then abort. 9 times out of 10 this shuts the process down. I think somewhere along the line when you kill a plate solve in mid stream the command to abort gets hung up somewhere. I don’t know but I do know this works and prevents me from having to restart.
