Populate from Astrobin not working
Is it just me or has Populate From stopped working when using Astrobin links?
I’m running 3.0.3.151 and when using an Astrobin link (e.g. https://www.astrobin.com/281880/), clicking “Check” returns Success, but after then clicking OK in the Target Settings dialog, the RA and DEC remain unchanged.
Given the initial Check appears to work, this looks like a problem with SGP rather than the Astrobin site.
Is anyone else seeing this problem?
thanks!
Steve
That image is not plate solved by Astrobin so you cannot use it in SGP. You will have to find one that has the coordinates on the right side of the page. I think that’s where they are.
Charles
Hi Charles,
Thanks for the response.
When I enter that link in SGP and click “Check”, it comes back as “Success” which should indicate that it has been plate-solved. Some Astrobin links I’ve tried do indeed fail the “check”, but not this one.
And I have tried several that pass the check but SGP still fails to populate the RA and DEC coordinates.
Here’s another image that passes the SGP check but fails to populate the fields: M33 (Triangulum Galaxy) ( pade ) - AstroBin
Does that image work for you when populating RA & DEC?
thanks!
Steve
Got in late from some failed imaging attempts but I will try those two Astrobin links and let you know my results. I’m on the latest build too though.
Charles
Quick update:
It appears that some plate-solved links are working as expected but others are not.
It also appears that the “Check” option is not working reliably: some images that are not plate-solved in Astrobin are passing with “Success”.
  1. M42 ( rkc ) - AstroBin
  • Appears as plate-solved in Astrobin
  • Passes the “Check” in SGP
  • Successfully populates RA/DEC
  1. M33 (Triangulum Galaxy) ( pade ) - AstroBin
  • Does NOT populate RA/DEC
  1. https://www.astrobin.com/281880/
  • Does NOT appear as plate-solved in Astrobin
  • PASSES the “Check” in SGP
  1. https://www.astrobin.com/221457/?nc=user
  • FAILS the “Check” in SGP
