Possible conflict Phd and ANSVR?
I’ve been running SGPro and PhD with very little problems, occasionally PhD will disconnect but it always seemed to come back OK. I just installed astrometry.net local and since both use CYGWIN, I’m wondering if there might be a possible conflict. Here’s what happened: I was imaging for about 5 hrs, everything working well, occasional PhD disconnect but always coming back online. SGPro was in the middle of a sequence when it suddenly aborted the sequence. This is from the log:
[PHD2 Listener Thread] Failed to establish client connection to PHD2 using port 4400: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 127.0.0.1:4400
Link to log: https://drive.google.com/open?id=1LtSU36V-cmrzvu4JSezCqw-x-iK_71yP
PhD was still running normally and continued to guide. Andy looked at my PhD logs and he suggested I try this forum since PhD was still running. From what I see in the SGPro log, it appears the PhD server went down but PhD didn’t report it.
I have my (win7) PC connected to a QSI683 camera, Lodestar X2 guider, G11/Gemini-1 and a few other odds and ends through an Icron Ranger USB->Ethernet adapter, and powered USB hub.
One other thought: I also use NoMachine to remote into the PC and, again, coincidentally??, I failed to connect to it although NoMachine does fail occasionally but never as hard a failure as this. The PC was otherwise running correctly, including PhD still guiding after SGPro reported a failure to connect I know, too many possibilities here to narrow it down but I’m leaning toward a ANSVR or NoMachine conflict. Obviously the first thing I’ll try is disabling ANSVR since that was the last thing I installed but that may take until Spring to test - winter has arrived in Ohio.
Any thoughts?
John
I do not see any evidence of that. If the PHD2 server were stopped it would have been recorded in the PHD2 log, and we only see the ordinary logging for the server starting and stopping at the beginning and end of the phd2 session, no other times. In addition, later on after the initial problem SGP was able to connect ( and disconnected a short time later.)
But SGP aborted the sequence because it didn’t get a response from
PhD…I’m still stumped. Maybe a fluke, we’ll see if it happens again.
Tnx
John
