I am using the latest stable SGP, Sequence Generator 4.0.0.700 (64-bit).
Equipment: 294MM, EFW, ESATTO,ARCO, RC8, Avalon Linear. ESATO and ARCO using firwmare 3.0
Everything is working fine except the new added ARCO. I am using the latest firmware and the rotator connects. When I go to platesolve, SGP moves the rotator to X angle, takes the plate solve image (rotator still moving) and even if I abort the platesolve, the rotator doesn’t stop until I stop it from the control panel (other tab).
I tested the rotator with another software, using the same platesolving software (astap), and the rotator is functioning flawlessly. Obviously, I would prefer to keep using SGP. I also tried the latest beta and the issue is partially solved (usually image taken when the rotator stops), but it never finds the correct rotation. I.e. rotation error 70 degrees, next step it will be 90, then 75, then 130, etc…
Here are some logs: sg_logfile_20220212012626.log - Google Drive
