Problem capturing images with SBIG STL-11000
I’m having a really strange problem capturing images in SGP with my STL-11000. I recently purchased a new PC to run my astro setup after my old one died unexpectedly. My old laptop ran SGP just fine and I never had any issues. My new PC seems to work just fine and SGP does not report any errors, however, the pictures are not right. There is hardly any signal present and the bottom of the frame is much brighter than the background sky, creating a gradient from top to bottom in the frame. The gradient is not from light pollution or any other source, it is being artificially generated somehow between the camera and SGP.
I’m positive that the problem is with SGP because when I use TheSkyX to capture the image everything looks normal. Below are two images, the first is a 10 minute exposure captured with SGP. The second is a 10 minute exposure captured with TheSkyX. These were taken minutes apart on the same night, nothing in the imaging train was changed! I have no answers for how this is possible, has anyone encountered this before or have any suggestions?
Are you using auto stretch with SGP? Is the temperature set the same between the two?
Back when I had a STL-11000 I had to keep it at -20C or I would get gradients very similar to this.
Jared,
I do have auto stretch enabled, but my understanding is that auto stretch is for display purposes only and does not actually change the original image. Is that correct?
The temperature is set to the same value between programs, but it is set at -15C, so slightly below your recommended -20C. I have successfully shot many images at this temperature without gradients so it would be unusual for that problem to suddenly occur.
Thanks for your help,
Joe
