I have problem with unexpected profile change. Situation is as follows:
- I open SGP with last sequence and proper profile (lets call it “800mm”) applied
- I connect everything (camera QHY9, QHYWRS232 filter wheel and rest of equipment)
- because of connection of QHY filterwheel through USB I have blank field in “set filter position” in “filter wheel” window. I have to choose “lum” filter and click “set” - in this moment profile sometimes (!) changes to “632mm” (settings for telescope with reducer)
- if profile will not change in situation mentioned above, it changes after I make “slew to target” - after slew profile changes to “632mm”
I have noticed that when I open SGP in sequence window there is " * " on the bar with sequence name - “sequence_name.sgp*”. After profile change " * " vanishes when situation described above happens.
I have checkbox checked “use profile as default for new sequences” for profile “632mm”, but… I to not create new sequence in this situation.
