This is RE 2.6.0.24. I do not need any of the present features in 3.X so have not upgraded yet.
This is pretty annoying and (maybe) could lead to problems. My friend and I are operating a dual scope system at a remote site. That means we have both two user profiles and multiple equipment profiles.
I have found that if I load a saved sequence, all is fine until I change the sequence. (note that the equipment setup has not been touched). Once I make a change to the sequence, suddenly the text at the top says “no equipment profile”. OK, so then I have to apply the correct “profile to sequence” but when I do that it dumps the user profile so I also have to re-select that.
Rather annoying. Is this normal and what effect could it have? I am concerned that it might apply the wrong equipment and result in trouble.
I have noticed this too, but ultimately the equipment profile doesn’t
matter. The equipment profile only serves as a template when you first set
up the sequence file. When you close and re-open a sequence, or make
changes to the sequence, there is no need to apply a profile because the
sequence already has all (or most if you changed something) of the settings
intact. Or am I not understanding something?
Now this could be an issue with user profiles, but since you are at the
same location I wouldn’t think that would be an issue either.
I should add that I noted last night (on two systems) that you need do nothing at all to have the profile disappear from the text at the top of the sequence box. It goes away all by itself at some point during the night’s run.
Maybe not important but it sure does not seem like it should do that.
