There still is a problem with the program locking up when a blind solve is aborted. A log cannot be provided since the program is locked up. I have use task manager to shut down SGP and then restart it.
Are you sure SGP is locked up? Often when it appears locked up, there’s a hidden dialog box waiting for a reply. Next time it “locks up”, do Atl-Tab to see if the dialog box is in the list.
If not, try pressing Enter or ESC.
I tried those things and they did not work. The program also cannot be closed. Task Manager is the only solution. The bummer for me is when I close SGP my Optec Gen 1 rotator has to be homed again.
I too have to do gymnastics with my fingers to get the hidden dialog boxes for that brief moment when you can click to exit the feedback loop.
It’s gotta be a bug.
Those pop ups should be layered such that the active ones are on top.
I too have this same issue. If blind solve is aborted, SGP locks up and the only way out is with Task Manager to Quit SGP. Then all equipment disconnects (camera cooler) etc.
