Puzzlling Problem
Hi everyone,
For the past couple of nights I have been experiencing a strange and unexpected problem. I am using a Losmandy G11 with Gemini 2. My computer is connected via a direct network cable. I cold start the mount and do not use modeling, letting the plate solving software do all of the point. I have been for sometime taking a four plate Mosaic of M31. Up until the last couple of nights everything has gone off flawlessly. What is happening now is as follows:
  1. I run the first event flawlessly. The plate solver sends my camera to the right place and everything works fine.
  2. On the next event, the plate solver slews the scope fine, and the image is usually within a 100 pixels of being centered.
  3. The next slew lasts an inordinate amount time and the next plate solver image comes back with large star trails.
  4. When I go out and check my mount I find that it is pointing to an entirely different place in the sky, way away from where it was just minutes ago.
  5. Last night this same problem reoccurred on the third and the fourth event.
  6. The only way I can get back running again is shut everything down and start from scratch, but this just allows me to do one more event. It doesn’t solve the problem.
Today, I have updated the Gemini.net ASCOM driver and the Gemini firmware, thinking maybe this is a communication problem.
What is your take on this? I hope someone has a solution.
Rob Fink
An interesting problem. I have experienced a comparable problem on a much smaller scale. I have the plate solve identify a small pointing error and then see it drive to correct the small error. The problem is that it does not drive to the correct place but to a seemingly random place where the next solve therefore also calculates an error. This process continues until the default (3 times) kicks in and the sequence fails. This happens every time. I reported it, and also another strange plate solve success/pointing failure problem but there has been no reply so I am no further forward.
To fix the above I had to abandon solves (!!!) and point by hand to get any imaging done. BTW all my settings appear to be correct.
I hope that you will fare better.
Lawrence Harris
I think you will need to share log files from SGP and Gemini 2 to figure out what is going wrong.
Wrong post;-). My scope is not the G2. FWIW I did post log files with my
problem but there was no response.
Lawrence
Lawerence,
Have you checked your sync behavior on the telescope tab in the sgp control panel. It should be set to sync. I stumbled across that last night as I was solving my own problem which turned out to be a faulty net work cable. I found if i didn’t have have it set to sync, it never centered.
I hope that helps,
Rob
Thanks for your response Rob.
Yes, it is set to sync. I had been through everything very carefully but still I cannot achieve even one sequence target without bewildering error messages. It is also worrying to see ‘rotate’ included in the settings when I do not use a rotator yet have to accept a setting that includes it. It says 'attempt to center/rotate one time. I previously had the number set higher but the scope was going all over the place despite calibrations from solve.
:confused:
Lawrence
Have you brought this problem up in the Gemini forum? You may have some kind of communication problem going on between your computer and your mount. I have found that a lot of times the issue has nothing to with the software but my own equipment. I have also discovered that there is always a solution. If you have a Losmandy mount, the support forum there is fantastic.
Rob
As I explained, I don’t have a Gemini mount. It is the SGP error message etc that caused me to post. I experienced the same problem as the original poster.
Lawrence
The original poster is me, and I found my problem to be a faulty network cable. I recieved sgp error messages too, but my problem turned out to be a hardware problem. My problems disappeared when I did two things: replace the network cable between my computer and the mount and secondly adjust my mount safety limits.
I feel for your frustration, but I assure you that there is a solution.
Rob
