Description
Since yesterday after updating to the latest version of SGP, I can no longer connect to my Planewave focuser via SGP. The PWI3 software launches and connects to the focuser successfully, however I then receive an error as below
I have tried installing a prior version of SGP but the issue is still there. I also downgraded to Win10 from Win11, but still no difference. I also uninstalled PWI3 and reinstalled, but no difference again.
For reference the PWI3 software does connect to the focuser successfully, TheSKyX can also successfully connect to the focuser as can ASCOM diagnostics utility. The ASCOM log file (link to that and other logs below) shows an error as below:
UNHANDLED EXCEPTION DURING REFRESH: System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize —> System.Configuration.ConfigurationErrorsException: Unrecognized configuration section system.serviceModel. (C:\Program Files\Sequence Generator Pro 64bit\Sequence Generator.exe.Config line 522)
Link to Logs
Useful Info
OS: Windows10pro 19044.1645
**Ver:**4.1.0.772
