Hi, I’m installing SGP x64 on a new laptop. It’s the first time I’ve done a fresh install in many years and the first time I’ve run it in 64 bit and I’m running into an issue with my QHY camera. Basically, the QHY camera option (QHY Camera-Capture I believe) does not show up in the Control Panel Camera drop down list, so I cannot use my QHY with my old profiles right now.
I’ve done a new install of the QHY all-in-one driver pack and the drivers seem to be working and are updated properly. The camera works in both SharpCap and EZCAP-QT x64. Is there an easy step I’m missing for SGP to be able to identify the QHY drivers? Does it use the ASCOM driver or one of the other ones? I know last year the QHY drivers had an issue with the 64 bit version but I believe that was quickly rectified.
Should I try downloading the 32 bit version of SGP to see if it works in that? Thanks.
