Hello - hopefully someone can help me out on this. I’m toying with importing targets from AstroPlanner (my primary planning/session catalog app), and while I can import target name and ID (i.e “Whirlpool Galaxy” and “M51”), the RA and DEC values in the XML document do not seem to populate the corresponding Location fields in the Target Settings dialog. I’ve tried a few different formats (beginning with that shown in the RA/DEC fields), but no luck so far. Has anyone had success in getting this to display?
Not sure. My copy of astroplanner does output that data, but I am no
astroplanner expert. You might want to reach out to the author of
AstroPlanner to figure out why that data is not in your exports.
Ken - thanks for the response. AstroPlanner actually puts the data into the XML file (see below), the problem is that while the target name and ID is accepted by SGP, the RA/DEC values don’t seem to carry over (I am assuming they should show up in the Target Settings/Location fields - I could be wrong about that…).
I put together a quick video of how I got my imports into SGP. Make sure
when you save the xml file to add the extension to the file name. Somehow
it saves it at .txt which SGP does not look for. I use the default formats
for everything.
Thanks Moussa - for some reason your video isn’t loading, but if you would be kind enough to confirm what I’m seeing, perhaps I’m just mistaken on how this should work. I did indeed discover the need to manually change the suffix to .xml.
This is what I see in the Target Settings dialog:
I assume that I should see the RA and DEC from the XML data populate the Location RA and DEC fields. Instead, the default zeros remain.
Awesome. Glad it is working out. Astroplanner has a Imaging Planner script you can download from the GUI that can give you a list of times to image based on your object list. Convenient for doing multiple targets per night.
The first step is to make Astroplanner export those fields…We can
probably reach out to Paul Rodman and see if that is possible…Then
importing that into SGP should be relatively straight forward once Ken and
Jared clear their baaaaacklog :-).
