I´m having strange but serious problems with random disconnects of EQMOD and Motor Focus.
The Motorfocus has most issues, normally it will connect only on the 3rd try. Sometimes SGPRO stating that the focuser is not an absolute focuser (which it is). A reconnect solves at least this issue.
The disconnects happens once or twice a night. While EQMOD and the Motorfocus still can be operated by using EQMOD interface or the dedicated handbox for the motor focus. Also Guiding via PHD2 and EQMOD continues, even if disconnected from SGPRO.
The disconnects only happen when the Motorfokus is moving (that is my experience so far, but cannot be sure).
I tested so far:
Changed cables
checking all contacts
uninstalling/ reinstalling drivers
Not sure if it is a SGPro issue at all, but hopefully someone can support what to do next.
I usually find, bad connections \ disconnects are all down to dodgy over-long cables.
I use Lindy Croma cables, and to get them to the shortest possible length, I have a pier mounted PC and a StarTech USB3 Pro hub (powered) which everything runs from. This pc is networked so I access it anywhere.
Touch wood (my head), I haven’t had any issues in 3 years, apart from when I go off to Star Camps & I’ve forgotten something.
Thank for your input, in fact I´m also using Lindy cables bundled and at the length required. Tried also different cabling. So far I can exclude connection problems as a root cause…
Thanks again!
I think I finally found the culprit, at least this night everything worked like a charm.
In fact the wireless antennas from MiniPC sitting on the mount were extremely close to the EQMOD and Motorfokus USB cables.
Moving it further away seemed to have solved the issue.
Maybe my experience here can help others having strange problems.
