I’ve had my Atlas Pro out a few times now without seeing this issue, but tonight I could not get it to plate solve. I could do a blind sync and solve, and then I put a link in from astrobin and hit center now I either get an error message (see pic below) and the mount doesn’t move or it slews and then cant seem to make adjustments to center the target. I’ve attached what I think is the failure from the logs. Thanks!!
/18 21:34:14.683][DEBUG] [Telescope Thread] *********** SUCCESSFUL SOLVE *******
[10/10/18 21:34:14.683][DEBUG] [Telescope Thread] SOLVER: False
[10/10/18 21:34:14.683][DEBUG] [Telescope Thread] SUCCESS: True
[10/10/18 21:34:14.683][DEBUG] [Telescope Thread] CONF: 399
[10/10/18 21:34:14.683][DEBUG] [Telescope Thread] BLIND: False
[10/10/18 21:34:14.683][DEBUG] [Telescope Thread] RA: 0.976533223202711
[10/10/18 21:34:14.684][DEBUG] [Telescope Thread] DEC: 60.9759057658571
[10/10/18 21:34:14.684][DEBUG] [Telescope Thread] SCALE: 3.33551
[10/10/18 21:34:14.684][DEBUG] [Telescope Thread] FLIPPED: False
[10/10/18 21:34:14.684][DEBUG] [Telescope Thread] ANGLE (EON): 356.27
[10/10/18 21:34:14.684][DEBUG] [Telescope Thread] MSG: Valid solve.
/18 21:34:14.684][DEBUG] [Telescope Thread] ************************************
[10/10/18 21:34:14.684][DEBUG] [Telescope Thread] Auto center validation frame solved successfully…
[10/10/18 21:34:14.684][DEBUG] [Telescope Thread] Telescope: Syncing to J2000 RA: 0.976533223202711 Dec: 60.9759057658571
[10/10/18 21:34:14.684][DEBUG] [Telescope Thread] Telescope: Sync behavior set to “Sync”…
[10/10/18 21:34:14.693][DEBUG] [Telescope Thread] ASCOM Telescope: Error in Sync : CheckDotNetExceptions ASCOM.SynScanMobile.Telescope CanSync Get System.Net.Sockets.SocketException (0x80004005): A blocking operation was interrupted by a call to WSACancelBlockingCall
at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP)
at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP)
at SwCsCommon.UDPComm.Read()
at ASCOM.SynScanMobile.ConversationManager.ConverseStaticInternal(IComm comm, CommunicationStats cs, ResponseCache responseCache, CallerType callerType, Command command, ArgsChecker argsChecker, ConverseParams convParams)
at ASCOM.SynScanMobile.ConversationManager.ConverseGetBoolean(String cmd, ConverseParams convParams)
at ASCOM.SynScanMobile.Telescope.get_CanSync() (See Inner Exception for details) (System.Net.Sockets.SocketException (0x80004005): A blocking operation was interrupted by a call to WSACancelBlockingCall
at ASCOM.SynScanMobile.Telescope.get_CanSync())
at ASCOM.DriverAccess.MemberFactory.CheckDotNetExceptions(String memberName, Exception e) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 630
at ASCOM.DriverAccess.MemberFactory.GetTargetInvocationExceptionHandler(String memberName, Exception e) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 664
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 231
at ASCOM.DriverAccess.Telescope.get_CanSync() in C:\ASCOM Build\Export\ASCOM.DriverAccess\Telescope.cs:line 451
at p7.kg(Double A_0, Double A_1, Boolean A_2)
