I use platesolve all of the time. I use ASTAP for platesolving through SGP. There are times during an imaging session when I want to re-run platesolve to make sure that the next imagies will be cenered correctly. How do I command SGP to re-run platesolve to re-cneer the iamge
REMenard,
In your Equipment Profile, look in Target Centering. In the Periodic Recentering section tick the ‘Center Every - FRAMES’ checkbox and stick in the box the frequency you desire. This will bake the setting every time you run any sequence.
Checking this option in ‘Control Panel’ instead will apply it to your current sequence but will not be perminent every time.
Hope that helps
PAaul
This is correct but please note that this feature only exists currently in the 4.5 beta (which is pretty stable at this point)
Sequence Generator Pro 4.5.0.1578 (BETA) is Released for Test - Releases - Main Sequence Software
