Can anyone shed any light on why my Recovery mode last night didn’t go through the normal sequence finish procedures. There was cloud over at about 02:30 Recovery mode kicked in. This morning the cooler was still on and the mount hadn’t parked as per usual. The sequence was due to stop via ‘finish capture’ procedure at 03:50 - This is the way I have always finished a capture and then it usually parks and does it’s thing!
It looks like recovery ended properly at 3:50, but erroneously indicated success in recovery which caused the sequence to try and continue instead of running end of sequence options. This state is pretty hard to reproduce… it seems to be a timing issue, but I think I have found the issue and corrected it.
