I’ve noticed on the last two sessions a lot messages that something terrible has happened, before going into recoevery mode. However, the programme did recover and proceed ok eventually. I have a feeling it might be a guiding issue, but would be grateful if you could point up any information from the log that might help the trouble shooting process.
TIA for any input
Aprox time of issue: 23.30 20 May (and others)
Link to Logs
Useful Info
OS: Microsoft Windows 10 Home Ver: 3.1.0.457 .NET: 4.8
Run your SGP logs through SGP Autofocus Viewer. You’ll see that your autofocus settings need adjusting. Your HFR minimums are around 1.2 but your maximums at the curve tails are only around 2. You need to increase your step size until those tail HFRs are around 3 to 4. Perhaps try increasing the step size from the current 20 to 30 or so, and see how that goes. From memory the recommended ratio of max HFR to min is around 3, so 3 * 1.2 is 3.6 HFR at the curve tails.
