How does one reset the plate solving integration time in Recovery Mode?
Sequence recovery does not have its own plate solve frame integration time settings, but rather uses, the same setting that all plate solves use (globally).
In both the sequence’s control panel and the equipment profile manager, this setting is available on the Plate Solve tab.
Hi Ken…I cannot check at present…but I am of the opinion that when doing a recovery plate solve it doubles the time in the settings. I use 10 sec exposures normally for my plate solves…pretty sure it takes 20 second exposure when doing a recovery plate solve. Maybe someone else can comment here before you go checking further.
You could be right… I’d need to go verify this (and will later).
