After deleting images generated by the mosaic tool when creating a new event and saving the sequence
they still reappear when I next open the sequence. Is therea trick to permanently removing these? Screen shot below!
It’s possible there’s a bug and we can look…
- How did you go about removing them? With the Sequence File Manager tool?
- After you removed them, did you save the sequence?
I just tested this in the latest 4.1 and it seems to be working fine? I am adding a bit of code to, upon removing the image from the sequence, to also close it if it’s open, but I didn’t have any issue actually removing the images.
Hi Ken
I didn’t know about the SEquence File Manager tool! I just closed the images.
After closing them with that they stayed closed.
Neil
