Several releases ago (?) when auto-focus was running and the bottom of the curve was left of center, the focus would continue taking images past the number I specified until it got a nice “U” curve.
Now when the bottom of the curve is left, the auto-focus moves the starting position out then restarts.
Is there a setting to return it to the prior behavior? I have Disable smart focus OFF.
My CCD camera takes about 11 seconds to download an image so restarting focus can add a couple minutes of lost time.
Here are a few log lines that indicates it doesn’t even consider extending the left side.
[08/25/23 00:56:27.731][DEBUG][Main Thread][SQ;AF;] Adding sequence level notification: Cannot find focus point, assuming focus is outward, adjusting smart focus range... [08/25/23 00:56:27.794][DEBUG][Camera Thread][SQ;AF;] Sending Notification: Warning - Cannot find focus point, assuming focus is outward, adjusting smart focus range... [08/25/23 00:56:27.801][DEBUG][Main Thread][SQ;AF;] Adding sequence level notification: Focus cannot be determined. Moving to start position of 30611 to reattempt. Fit Quality 88%
