Roll off roof closing issue
Rasa8 with motoried and arduino control roll off roof observatory.
I have searched the forums and other places for an answer and I am baffled. My roll off roof has worked flawlessly for years with SGP. Recently it has started powering off the equipment before the roof closes. I have the Disconnect all equipment at sequence end checked in the Sequence panel. If I uncheck this the shutdown process closes the roof but does not disconnect the equipment. If I check the box the shutdown process disconnects the equipment and leaves the roof open.
The observatory settings are:
Slave to scope on sequence start
Mount unpark opens roof
Open roof first, then unpark mount
Mount park closes roof
Park mount first, then close roof.
I have toggled all these settings off and on as well as Slave to telescope but nothing has resolved it yet. It seems to have started when the control panel was integrated with all the options in one place but this is a guess.
If I unpark the scope (roof opens) and then tell SGP to run end of sequence operations, it parks, closes roof, and disconnects equipment (assuming the disconnect check box is checked).
SGPro 4.5.0.1652
Stan
Did anything change recently? New drivers, etc? The version of SGPro in use is very old so I assume that’s been the same across the timeline here?
No changes of any kind. In fact, I have not used the observatory in over a year. I checked for. updates in SGP and downloaded what i thought was the latest version.
The version is a typo. it is 4.5.0.1652
If you’d like to send logs they will almost certainly add context here. You can send them directly from the SGPro app itself. See here:
I sent the log file but couldn’t find the issue in the dropdown. Had to create another entry in the forum support. Sorry
That’s just fine. It is likely an issue with the reporting tool, but I see the other thread.
Thanks for the report. I reviewed the log and was able to locate a timing problem where this type of behavior can result. I will try to release a beta build with this fix here shortly.
Thanks Ken! I am glad it wasn’t something dumb that i was doing or not doing.
Stan
I am in absolutely no rush at all but you didn’t post the beta build somewhere that i have missed did you?
Stan
The beta is under test. Will release soon.
Thanks Ken! The beta resolved the roll off roof closing issue at sequence end.
Stan
