Is there a way in the framing and mosaic wizard when you’re doing the rotation that you can rotate the square that you have drawn and not the image? If I place a square down, and then hit rotate, the whole image rotates and then I have to move the square. It’s not a big deal.
I just had a quick look…why don’t you set your rotation angle first…then put your square down.
Yes, I can do that. Sky Safari and NINA allow you to rotate the frame which is more convenient to me. As I said, it’s not a big deal.
And of course, NINA has an open feature request to rotate the image, not the framing square…
