Perhaps the fault of the ASCOM driver, but with my DIY rotator I am seeing this:
[02/25/20 18:55:08.784][DEBUG][Telescope Thread][SQ;CE;] Performing auto center step 3 (rotator)…
[02/25/20 18:55:08.784][DEBUG][Telescope Thread][SQ;CE;] Moving rotator to 180.0…
[02/25/20 18:55:08.787][DEBUG][Telescope Thread][SQ;CE;] ASCOM Rotator: Moving rotator to 180
[02/25/20 18:55:08.787][DEBUG][Telescope Thread][SQ;CE;] ASCOM Rotator: Sync offset is -160527.244995117
[02/25/20 18:55:13.858][DEBUG][Telescope Thread][SQ;CE;] ASCOM Rotator: Error in Move(abs) : Timed out waiting for received data (System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Runtime.InteropServices.COMException: Timed out waiting for received data
— End of inner exception stack trace —
at System.Type.InvokeMember(String name, BindingFlags invokeAttr, Binder binder, Object target, Object[] args, CultureInfo culture)
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 443)
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 483
at ASCOM.DriverAccess.Rotator.MoveAbsolute(Single Position) in C:\ASCOM Build\Export\ASCOM.DriverAccess\Rotator.cs:line 105
at SequenceGenerator.AscomRotator.g8(Single A_0)
[02/25/20 18:55:13.858][DEBUG][Telescope Thread][SQ;CE;] Rotate failed…
[02/25/20 18:55:13.858][DEBUG][Main Thread][SQ;CE;] Adding sequence level notification: Rotate to reference failed.
[02/25/20 18:55:13.908][DEBUG][Telescope Thread][SQ;CE;] Sending Notification: Error - Rotate to reference failed.
[02/25/20 18:55:13.908][DEBUG][Telescope Thread][SQ;CE;] Auto center failed! Camera rotate failed.
[02/25/20 18:55:13.913][DEBUG][Telescope Thread][SQ;CE;] Close centering dialog…
however when the sequence recovers everything is fine without further rotation adjustment, so it seems like just a timeout problem.
This is SGP 3.1.0.452
Targets, with different rotator angles, are working fine, other than this issue which seems to happen at the start of the sequence each night.
