Hi I was using prevous version SGP without any problem till yestreday night. Yesterday night i installed the update 4.1.0.794. after installing update i could not connect the equipment (exactly the same equipment that were working with previous version with out any problem) SGP started to give the messsage ‘’ RPC server is unavailable (exception from HRESULT 0x800706BA) and also i couldnt use my existing profiles.
if you have any solution please suggest
thank you
