If I have more than one target in a sequence could I be allowed to save each target to it’s own file.
Rich
Rich
To its own folder? Sure, my default path is:
%d2%tn%ft%tn_%yy%mm%dd_%tm_%fz_%fl_%ft_%el_%bi_%ct_%su
It uses the day (minus 12 hours), then a folder for target name, then frame type, then the individual exposures.
So BH let me see if I understand you. In General options if I set
Default Image Directory C:\Astro Images
Custom file name pattern to %tn%dt_%tn %el%fn_%ft
Then after my imaging session I would find
C:\Astro Images\IC2118_02-09-2015\Lights and in that folder would be Image IC2118_900Sec_frame1_.CR2
C:\Astro Images\ M101_02-09-2015\Lights and in that folder would be Image M101_900Sec_frame1_.CR2
I should have discovered this on my own. I didn’t realize it was so easy.
Closed as invalid.
