Hi everyone, i have some questions about pre/post event scripts.
the PDF documentation says that EXE and VBS files are supported, however, when i try to open a script, apparently only VB files are supported. are EXE files really supported? i pointed to a directory with a bunch of .exe files and nothing showed up in the file chooser. there does not seem to be a way to unfilter on “VB files”.
also is SGP passing the script thru cscript.exe ? if so, which version does it choose (64/32 bit)? from reading the microsoft documentation apparently cscript.exe can parse and compile javascript as well as VBS, so can SGP choose a .js file as a script?
next, it looks like TCP sockets are a real ball of hurt in cscript.exe - there does not appear to be a native object which lets you use sockets. it seems that you can install a dll from visual basic (but the installation is quite torturous), or there are some 3rd party objects/dlls that one can use. they seem sketchy though. is there best practice here?
finally if EXE is supported i was thinking about using something like perl2exe to get a windows executable, since i’m a heck of a lot more comfortable with perl than visual basic or even javascript.
thanks,
rob
