Hello.
I have recently built an arduino based Scope Cover, to be exact with Seeduino Xiao. The scopecover works well, and is programmed so that SGP detects it as a flats sheet, but I can’t get it to read the port assigned by the PC.
It is well recognized by the PC, but SGP does not detect it. Can someone help me? Thank you.
This is the link with the code. I can’t send the archive for the format
@Jared wrote all of the non-ASCOM flatbox stuff. He may have some advice here…
Just i fix the problem!! it´s working perfectly… it´s my first arduino program, and create an Ascom driver… Thank you!!
You shouldn’t need an ASCOM driver. That should work with the Alnitak (Old) implementation that is in SGP. But either way, glad you got it going.
I already tried with old alnitak, but it didn’t work. Is it possible that the open and close commands are wrong? o SGP does not recognize the 000\n or OOO\r commands. It is the same as your .ino driver.
You may want to also try this version which has been updated:
Great, Jared, I’ll try it and let you know if everything works well. Thank you so much.
Finally I was able to make it work with the Ascom driver, everything was perfect. Thank you
