Last night my sequence failed to start. After connecting all of my equipment I clicked on start sequence and received the following message: Error initializing notification system endpoint “Text File 1”. See log for additional details.
I tried restarting all of my programs, rebooted my PC and even redownloaded the recent version of SGP and I still received the same message.
I hope it’s something simple and hope you can help. Below is a link to two log files.
It is indeed a simple issue to fix. Somehow you have enabled the test file notification endpoint, but it is misconfigured. You’ll either need to correct that or disable the endpoint.
I looked into this Ken, and you are correct, somehow an endpoint task got checked. I unchecked the box and I will see what happens. Thanks so much for your help and I’m sure glad it was simple.
