Sequence Generator Pro 2.3.8.2427 is released.
Changes:
- Added a feature that allows equipment profiles to override the file naming pattern (if left blank the file naming pattern in the options dialog will be used)
- Fixed a bug that would not honor the target order if your altered it before starting the sequence.
- Fixed a bug that could cause SGPro to crash if an Elbrus plate solve failed.
