Sequence Generator Pro 2.4.0. (Beta 10) is Released for Testing
Sequence Generator Pro 2.4.0. (Beta 10) is released for testing.
SGPro 2.4 (Beta 10) will require PHD2 2.4.1e or better to function properly: You can download it here: http://openphdguiding.org/snapshots.html
Beta 10 Changes:
  • Fixing a bug where TEC cool-down on camera connect would fail if the cool-down period was 0 minutes
  • Fixed a bug that would cause user profiles to break completely if the profile location was moved to custom location
  • Blind solves will now send scale and error of 100% (you can override error in ANSVR settings). ANSVR, when used as the primary solver, still sends the scale with 5% error. This allows blind solves to be truly blind (or it allows you to customize the blind solve error via ANSVR settings)
  • The cancel button for auto focus will now cancel all auto focus activity during that session (and not just from the last run)
  • Fixed a bug where the event in-progress arrow would disappear when clicking on other targets
  • Removed dependency on ASCOM AstroUtils library
  • More help file updates in preparation for the 2.4 release
  • More tooltip updates in preparation for the 2.4 release
Beta 9 Changes:
  • Removed the “Pause guider during image download option” (this has not been functional for a long time so don’t worry if you were using it before)
  • Fixed an issue where Canon previews were sometimes displayed in the portrait orientation
  • Might have fixed an issue where SGPro might crash when querying for position
Beta 8 Changes:
  • Added an option to force auto focus to use the weighted average of the lowest 3 HFR / FWHM points in order to calculate focus position. You should avoid this using this option if possible (and instead spend time tuning your settings). If you would like to use it, it can be found in the Auto Focus Options (“Scope has central obstruction”).
  • You can now create sequences from the Mosaic and Framing Wizard that Auto Center, Slew or do both for each target
  • Adding all keyboard shortcuts to help dialog
  • Huge update to the help file in preparation for release
  • Adding option to stop the mount in place (stop tracking) when the sequence terminates (as opposed to park)
This topic is now a banner topic. It will appear at the top of every page until it is dismissed by the user.
This topic is not a banner topic anymore. It will no longer appear at the top of every page.
