Hi folks,
SGPro 2.5.1.1 is a beta release. While we love that many of our users are eager to help us test, make sure you are a fairly knowledgeable SGPro user before hopping onto the beta track.
2.5.1.1 Changes:
- More changes for the new auto focus method
- Added a minimum star size (in pixels) slider. This can be adjusted using the slider below “Nebulosity Rejection”.
- The minimum star size is a “per-target” setting. You will likely want to have, for the same set of equipment, the same minimum star size (no guarantee here… just a rule of thumb). If this is true, we will find a way to work this into the equipment profiles later.
- Nebulosity Rejection is still disabled (not needed)
- General improvements on star detection technique
- Note: With this new method, you should not be dissuaded if it only selects a few stars from what looks like a field of eligible stars (the new routine, assuming proper minimum star size, is far more resistant to false star detection).
- AFPacks now take a screen shot of your AF graph automatically and save it with the FITS files that belong to that run.
- Fixed a bug that, when turning on the option to always finish calibration frames from the options dialog, might not actually allow this to happen.
2.5.1.0 Changes:
- Major refactor for Auto focus ([See here for more details][1])
