Sequence Generator Pro 4.1.0.712 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
Sequence Generator 4.1.0.712
Changes
- For switches that are part of the sequence, SGPro will auto-connect to them at sequence start and ignore any others.
- SGPro will no longer attempt to auto-connect to switches when a sequence is not running.
Fixes
- Fixed an issue that would cause the image navigation tools (back and forward) to not function properly.
- Fixed an issue where a sequence may fail to open due to an image history load error.
- Fixed an issue where a sequence may fail to open when another sequence is currently background loading.
- Fixed an issue where a sequence might open with red X boxes in the sequencer window.
- Fixed an issue where a target event may not deletable.
- Fixed an issue where an open or save dialog may not open.
- Fixed an issue where certain buttons may render with a red X.
- Fixed an issue where deleting an event may fail.
- Fixed an issue where deleting an event may leave a blank row in its place.
- Fixed an issue where SGPro might lock up when attempting to select a new target.
- Fixed an issue where the FITS header dialog would not render the HDU tab control.
- Fixed an issue where trend arrows for environment data may show a red X.
- Several errors on SGPro exit have been corrected.
- The color of the switch device title text has been altered so that it is more visible in dark themes.
